Transferring larger files to an Amiga 3000
schombi
Post by schombi »
Is there a way to utilize a HxC to transfer *.lha files (larger than a usual ADF) from PC to an Amiga 3000? I was experimenting with split tools, such as HJSplit and then create multiple small files and convert them to HFE, but it didn´t work. As this is on an Amiga 3000, which has SCSI, I cannot simply use a CF adapter for IDE or PCMCIA, as one would do on an A1200.
Any help is very much appreciated.
Re: Transferring larger files to an Amiga 3000
schombi wrote: Tue Feb 04, 2020 8:16 pm Is there a way to utilize a HxC to transfer *.lha files (larger than a usual ADF) from PC to an Amiga 3000? I was experimenting with split tools, such as HJSplit and then create multiple small files and convert them to HFE, but it didn´t work. As this is on an Amiga 3000, which has SCSI, I cannot simply use a CF adapter for IDE or PCMCIA, as one would do on an A1200.
Maybe this ? :
viewtopic.php?f=5&t=1853
schombi
Post by schombi »
Sounds interesting. I´ll read through it. Thank you!
schombi
Post by schombi »
Hmm, with the given information it seems to be too much for the poor-minded, like me. I managed to copy over the hxcfe utility to the Amiga and I can execute it, list the parameters etc. What I didn´t get: How do I copy over e.g. an LHA file to a FAT32 USB stick, so it can get read and copied by the utility? When I try a HXCFE DIR DF0: there are no files shown.
The thing with the mentioned "HxC Floppy Emulator file selector" I don´t understand at all. Is it required or are just parts of it used in the Hxcfe Tool?
schombi
Post by schombi »
I need to add that I´m using FlashFloppy/USB stick. Is that even supported by the hxcfe tool? In worst case I could use my cased HxC on the Amiga, but would like to have a 1:1 floppy replacement.
Sorry but i only support users who have a true HxC firmware :
https://hxc2001.com/store/
schombi
Post by schombi »
I bought it a while ago,
Anyway, with some help I got it sorted. I tried
hxcfe dir df0:
where it should have been
hxcfe dir
only.
Maybe that´s also useful for other HxC users.
