an empty file "doublestep" does not work on version v2.2.2.1.
fyk
Post by fyk »
I have a question about HxC Floppy Emulator v2.2.2.1.
It ignores an empty file named "doublestep" in the raw files folder.
(HxC Floppy Emulator 2.1.24.1 can work it.)
However, there is KFRAWLOADER_DOUBLE_STEP in Internal parameters.
When KFRAWLOADER_DOUBLE_STEP is set to "1", It works fine.
Since Internal parameters can not be saved,
a setting Internal parameters is required every single time running HxC Floppy Emulator...
Fuyuki
Re: an empty file "doublestep" does not work on version v2.2.2.1.
fyk wrote: Sat Dec 28, 2019 1:44 am Hello,
Fuyuki
you can "save" this parameter.
just put an "config.script" file in the exec folder or in the kf raw folder with this line inside :
set KFRAWLOADER_DOUBLE_STEP 1
fyk
Post by fyk »
Jeff wrote: Sat Dec 28, 2019 2:51 am
Fuyuki
Thank you so much for your quick reply!
I could set it by "config.script".
Do you have a documentation about "config.script" and "Internal parameters"?
Best,
Fuyuki
fyk wrote: Sat Dec 28, 2019 3:18 am Hi Jeff,
Best,
Fuyuki
The hxc library run the config.script from the hxc software folder at startup and from the kf .raw folder if present.
There is currently only the command "set" which set one internal variable.
Here it is an script example :
https://sourceforge.net/p/hxcfloppyemu/ ... nit.script
This is the hxc library internal script used to setting up the default internal parameters.
config.script is executed right after init.script if present.
About the documentation, i will just comment a little bit "init.script"
fyk
Post by fyk »
Jeff wrote: Sat Dec 28, 2019 10:27 am
Best,
Fuyuki
I really appreciate the link.
Fuyuki
