Non FAT sd!!
lukebretthauer
Non FAT sd!!
Post by lukebretthauer »
So i have had a few of these HxC drives now, I'm about to do my sp1200 swell, but i have a reoccurring issue with the Emax 1.
I have several sd cards that i use, which at one time or another have all worked fine. It seems when i pull one and reformat it for some reason or another, it MAY not recognise the fat format after. I could take a card that previously worked for years perfectly, format it in fat32 and then boom the sd card never works again! No matter what i try... it very annoying. These cards can used for anything else mind you and format on the computer just fine.
FWIW, i use a hackintosh with el cap, with a belkin multi card reader. The emax is a hd, but upgraded se model. And yes i have ALL the appropriate files and downloads already. I currently have a working card with the basic hfe and cfg loaded up fine.
Anyone else getting this mess? I use sdhc, varying speeds and sizes.
Luke
Re: Non FAT sd!!
lukebretthauer wrote: Mon Nov 18, 2019 10:15 am So i have had a few of these HxC drives now, I'm about to do my sp1200 swell, but i have a reoccurring issue with the Emax 1.
Luke
Sound like your hackintosh doesn't format sdcard in fat32, or something like this. I will try this on my mac mini to check.
Have you tried to format them with another machine/os ?
lukebretthauer
Re: Non FAT sd!!
Tried the laptop which is an apple MacBook Pro 13 with el cap but no good.
The hackintosh was the only computer that ever made a working sd.
Shame because there seems to be nothing wrong with the cards themselves.
L
lukebretthauer
Re: Non FAT sd!!
Tried formatting on my GoPro hero 4, works every time. Now to stock up on micro sdhc’s.
Win :D
Re: Non FAT sd!!
lukebretthauer wrote: Tue Nov 19, 2019 10:20 am Tried formatting on my GoPro hero 4, works every time. Now to stock up on micro sdhc’s.
Win :D
ok fine. I will check this possible macOS issue anyway.
