Compatibility problems with Amiga 500 demos?
Strider
Post by Strider »
Hi!
I have an Amiga 1200 and some OCS demos don't work with my SD HxC Floppy Emulator.
I know this is not due to the AGA chip because several Amiga users told me these demos work on 1200.
9 Fingers (Spaceballs):
Loading is ok from disk #1.
But the demo doesn't want to load the disk #2.
I've tried several ADF and DMS versions of the disk images (found on TOSEC, pouet.net, scene.org...)
Hardwired (Crionics / Silents):
According to my searches, the demo does some measurements first.
Maybe it measures the speed of the floppy drive to know if it can run the whole demo?
(I know the demo measures for example the execution time of the multiplication and compares it to normal time on a 68000).
World of Commodore (Sanity):
Loading is ok at the beginning.
One minute after, the Amiga freezes with an error message (SOS System Error Nr $049) just after a disk access.
I would like to know if some Amiga users experience the same problems?
Do these problems come from the HxC Floppy Emulator?
[/list]
Re: Compatibility problems with Amiga 500 demos?
Strider wrote:Hi!
[/list]
Hardwired and 9 Fingers is working with the emulator (for WOC i don't know).
Please read the user manual page 7 and correct your jumper setting :
Strider
Post by Strider »
Jeff wrote: Please read the user manual page 7 and correct your jumper setting :
I've already set the right jumpers.
Maybe this is a problem with the A1200? In some days I should buy an A500, so I will tests these disk images on it.
In fact afters some tests it seems there are a regression somewhere.
Firmware update soon.
lotharek
Post by lotharek »
Jeff- some old demos work odd on 1200..
example - state of the art glitches on 1200 - works ok on 600
anyway, now all buyers know whya is valuable to buy Jeffs produckts --- IMMEDITATE SUPPORT and firmaware upgrades !
Well done Jeff !
ps. Your post -- Sat May 29, 2010 12:28 am
you also do not sleep ??
i`m fed up with licking postage stamps... i have licked almost 200 hundreds stamps....bleeeee
..... Atari Roxxx !!!
robert2098
Post by robert2098 »
lotharek wrote: i`m fed up with licking postage stamps... i have licked almost 200 hundreds stamps....bleeeee
You can use a wet sponge instead of your tongue.
In The Netherlands, stamps are nowadays self-adhesive. So not licking required :-p Maybe a tip for the Polish postal service.
Robert
lotharek
Post by lotharek »
Robert, that was just a joke ;-)
Strider
Post by Strider »
Old topic resurrection because I now have an Amiga 500 (with a 500 KB RAM extension) and I experience some problems with the same demos, except Hardwired which works perfectly:
Loading is ok. After about 1 minute, the visual effects go crazy and there is big crappy pixels on the screens, although the music still goes on.
Tested with ADF and DMS disk images.
Unlike my previous test on A1200, the demo doesn't load.
In fact it loads track 1, 0, 15 and then 1 and that's all.
Tested with 3 different disk images.
Can anyone test these demos on a real Amiga 500? I would like to know if there is a problem with the disk images, the HxC Floppy or the Amiga.
For information I have HxC Floppy rev B and firmware v1.7.1.2
Strider
Post by Strider »
Strider wrote: 9 Fingers (Spaceballs):
I found the problem with this one: in the settings of the HxC Floppy Manager the option "DF1 drive" was set to "on".
When I set it to "off", the demo asks me for disk 2 and all is OK now.
Maybe a bug in the firmware? :mrgreen:
(Note I've tested World of Commodore with DF1 drive disabled and it still doesn't work)
Strider wrote: (Note I've tested World of Commodore with DF1 drive disabled and it still doesn't work)
Use the new experimental HFE format and this will work ;)
Strider
Post by Strider »
Jeff wrote:Use the new experimental HFE format and this will work ;)
It works! You're my hero :lol:
