Gotek, HxC and TD0 Teledisk format
teevee
Post by teevee »
I have a few Akai disks which was dumped with Teledisk and I would like to use them on my Akai S-2000.
Akai dump Teledisk examples:
https://drive.google.com/open?id=1AG2Q4 ... QGspyEVFcx
I first tried using this tool, but it does not work on modern computers:
https://github.com/jmechnich/wteledsk?f ... zGEEssoH-w
I then tried downloading Teledisk and then thought that I could maybe write a disk with the software and dump the new disk with OmniFlop: (It only gave me errors, when I tried to write with this software)
http://www.classiccmp.org/dunfield/img5 ... ledisk.htm
Then I tried HxC Floppy Emulator Software, batch converter -> Akai S-950 HD as my pre-defined format. (This works, when you have .IMG files), this gives me an “Internal Divide error 0FE4 : A2…” on the Akai S-2000 screen, when I try to open the disk.
Any suggestions?
Re: Gotek, HxC and TD0 Teledisk format
TD0 / Teledisk are directly supported by the hxc software. just drag & drop them on the main window.
