Problem with long filenames in file selector (V1.89a)
siliconscientist
Post by siliconscientist »
Hi Jeff!
The file selector seems to have a problem with long filenames. In the folder view on the SD card they are displayed correctly...
...but if I put a file into one of the slots, the file name is shortened to 52 characters (hope I've counted correctly) until the next reset/reboot:
52 characters would be enough, but after a reset/reboot only 16 characters are being displayed which is a bit short really, especially with multi-disk games.
Now my question is: Am I doing something wrong or is this a problem in the file selector software?
Thanks a lot in advance!
siliconscientist
Re: Problem with long filenames in file selector (V1.89a)
Sorry, embedding pictures doesn't seem to work. Here are the links...
Folder view (SD card)
https://drive.google.com/open?id=19i8Tn ... e1YbXbc2sO
Drive A slots before reset
https://drive.google.com/open?id=1L7FVG ... -jDeVXADS8
Drive A slots after reset
https://drive.google.com/open?id=12DQKs ... 5DGqDtbfKh
Known issue : The problem is the CFG file version used. I need to update the firmware to support the V3 config files.
