Updating Hxc Firmware on Gotek
Kna
Post by Kna »
Updating a HxC gotek drive, i get the little snake-procedure, 3 flashes and then normal operation on the display. Is this error #3 "FAT error", or have I just updated the software successfully? (USB-stick is formatted with FAT32).
Re: Updating Hxc Firmware on Gotek
Kna wrote: Thu Oct 03, 2019 2:45 pm Updating a HxC gotek drive, i get the little snake-procedure, 3 flashes and then normal operation on the display. Is this error #3 "FAT error", or have I just updated the software successfully? (USB-stick is formatted with FAT32).
This is fine. You can check the currently installed version :
remove the stick, press both buttons, choose 'F' and read the numbers.
Kna
Post by Kna »
That worked and displayed the right numbers, thanks!
