Hxc and filenames
ZogZog
Hxc and filenames
Post by ZogZog »
I just find my old STE, so I decided to install a Gotek with HxC firmware.
Everything works fine, except one thing :
I format a Usb stick in fat32 and put in floppy drive emulator. I put in some folders the compilations of various groups well known.
When I select the disk and reboot with F7 the atari go back to the floppy emulator ? I find a solution, I must rename all the files with less ti 12 caracters.
What I done wrong ? I see peoples using disk images with long filnames ?
Thanks for your help guys
Re: Hxc and filenames
ZogZog wrote: Sun Sep 22, 2019 6:15 pm Hello,
Which firmware version are you using ?
Which file selector version are you using ?
ZogZog
Post by ZogZog »
I use the last firmware v3.4.7.11a and the HxC floppy manager 1.89a.
ZogZog wrote: Sun Sep 22, 2019 8:45 pm Hello,
Can you share one file causing this issue (without modify its name) ?
Also : Take care to take the CFG file from the firmware archive :
ZogZog
Post by ZogZog »
I tried the CFG file in the firmware archive, no result.
Here is a file :
https://transfernow.net/48ioy0g10q4u
Thanks for your help and your time !!
ZogZog
Post by ZogZog »
Thanks for the update, i will try After work.
Bikerbob
Post by Bikerbob »
Did whatever happened get resolved?
I am having the same issue.
James
Bikerbob wrote: Thu Oct 03, 2019 2:08 am Did whatever happened get resolved?
James
Yes with the v3.4.7.12a and newer.
Are you sure that this is the same issue ?
