Delay when choosing file and eject on startup ?
chrisf
Post by chrisf »
hi
i have just installed the latest HxCFEUSB_V3_4_1_4a_OSD.UPD
the on screen display is working fine (amiga), just a few small issues i cannot resolve -
on startup the buttons on the gotek take a while to begin to work as does the rotary encoder
this is even worse when you have to swap disks in a game , it takes 10 seconds for the buttons or rotary encoder to start working , i can bring up the osd instantly with a push of the rotary encoder button . just nothting happens when turning the rotary encoder or pushing the built in buttons for 10 seconds
also i cannot find an option to not have it boot anything on startup , i would like no images untill i choose one ?
i was using flashf firmware but wanted your on screen display as it a nice feature , just these issues im trying to resolve which all worked fine before on the other firmware .
many thanks
Re: Delay when choosing file and eject on startup ?
10 seconds ? are you sure ? There is some others users using the osd version and i never got this feedback.
Can you make a video of the issue please ?
chrisf
Post by chrisf »
this is my rotary encoder wiring as its a bare unit , no board - https://ibb.co/gSjgTbW
here is a video - https://www.youtube.com/watch?v=fqGI5Mq8OfA
it does the same thing when you use the 2 buttons on the front of the gotek
ive just found if you rotate the encoder alot it then starts working and you dont have to wait ?
also if you press the buttons on the front of the gotek 4-5 times that makes it start scrolling through the list as well
so 1 turn or button press does nothing ,but turning lots of times or pressing the buttons 4-5 times the makes it work
chrisf wrote: Fri Aug 30, 2019 5:43 pm this is my rotary encoder wiring as its a bare unit , no board - https://ibb.co/gSjgTbW
This is the wake-up button filter enabled in OSD mode. Press one button one second . i will test this with the rotary.
chrisf
Post by chrisf »
using this HxCFEUSB_V3_4_1_4a.UPD makes the gotek buttons and the rotary encoder act like it should , so as you say its a problem with the OSD version
chrisf wrote: Fri Aug 30, 2019 9:20 pm using this HxCFEUSB_V3_4_1_4a.UPD makes the gotek buttons and the rotary encoder act like it should , so as you say its a problem with the OSD version
Attached the OSD version with the wake up timeout value reduced. Let me know if this is ok for you.
HxCUSBFE.UPD
(87 KiB) Downloaded 583 times
chrisf
Post by chrisf »
hi
this is a lot better :D
as long as i press the rotary encoder in first , i can then turn it and select images instantly :D
if i just turn the rotary encoder without pressing in first it takes 7 rotating clicks before it changes to the next file
thanks jeff :D
Ok. Btw you can lower a little bit the resistor value to increase the contrast if you want.
chrisf
Post by chrisf »
hi
im using a 200 ohms resistor as its the closest one i had , its tends to be harder to read when the screen is white.
Another question , is it possible to make the OSD wider so it can show more text and move it to the bottom of the screen ?
thanks
chrisf wrote: Sat Aug 31, 2019 4:11 pm hi
thanks
Both features are planned. The OSD move function first !
chrisf
Post by chrisf »
thats great :D
chrisf wrote: Sat Aug 31, 2019 10:03 pmthats great :D
I have yet changed the rotary/keys behavior : https://hxc2001.com/download/floppy_dri ... rmware.zip
Let me know if this is ok or not for you.
chrisf
Post by chrisf »
Tested and non of the buttons or rotary encoder worked at all
other than been able to see the osd when first powered
chrisf wrote: Mon Sep 02, 2019 3:26 pm Tested and non of the buttons or rotary encoder worked at all
Sure ... :oops:
Tested and should be better now :
chrisf
Post by chrisf »
works perfect now
one twist of the rotary endcoder instantly goes to the next file :D
thanks jeff :D
