Auto mount USB stick folder - ADF support?
solarmon
Post by solarmon »
Any plans to have the Auto mount USB stick folder feature to be able to mount as an ADF image?
This would be useful on Amiga machines then since a stock Amiga does not support PC/DOS formatted disks.
Re: Auto mount USB stick folder - ADF support?
solarmon wrote: Mon Aug 12, 2019 4:50 pm Hi,
To do this i need to recode a complete amigados file system handler from scratch able to fit in the gotek flash. There is maybe a way to take some shortcut and make something with the minimal needed stuff.
solarmon
Post by solarmon »
Jeff wrote: Thu Aug 15, 2019 12:51 pm
OK. If it is non-trivial then don't worry about it.
I had a situation where I needed to get a file to a stock Amiga 500. I just ended up creating a blank ADF image using ADF Opus on my Windows laptop and putting the file in that.
solarmon wrote: Thu Aug 15, 2019 1:02 pm
You can do this with the HxC software too.
