EMAX-II "Please Insert Disk"
Demokid
Post by Demokid »
I'm very sorry for asking the same question again but I'm new to floppy emulators.
I just recently bought an Emax-II Keyboard (4 mb) with internal HD and got a HxC emulator (SD-card).
The HxC was not installed in the EMAX-II so I installed the emulator, with ID0A set to ON, all others Off.
I downloaded the QuickInstall_FloppyDiskImages and unziped SDHxCFE_Emu_Emax_II.zip.
I copied the following files to the root of the SD-Card:
035-ZD736-ElectricBass_em1.HFE
TR808_EM2.HFE
DSKA0000.HFE
DSKA0001.HFE
DSKA0002.HFE
EmaxII_OS_2_14_ZD777.HFE
HXCSDFE.CFG <-- selected 'Normal' config.
I insert the SD-card turn on the EMAX-II. I can hear the HD start and then I get the classic "Please Insert Disk!".
If I use the old floppy drive or turned the floppy cable around on the HxC, the EMAX-II boot from the HD (SCSI ID 2). I can load banks from HD but only the HD can be selected when pushing "Drive Select" button.
Anyone know what I've done wrong?
Kind regards
Demokid
Re: EMAX-II "Please Insert Disk"
For the Emax II the switch setting should be ID0-A (1).
Is the floppy ribbon connected correctly ?
Have you selected an file image ?
