USB HxC configuration can not be saved
Targhan
Post by Targhan »
My question is so simple, but I made a search and can't find any answer, so sorry if it's been asked 100 times already!
I have now a Lotharek USB drive emulator, it works perfectly with the HXCFloppyEmulator software. One problem: I have to select manually the Drive ID setting to DS1 every time I run the software, there is no way it can save it somewhere?
Re: USB HxC configuration can not be saved
Targhan wrote: Fri Jul 05, 2019 12:43 am Hi,
This is not implemented. But i can recompile the hxc usb dll to select by default the DS1 is you want.
Targhan
Post by Targhan »
If you can, that would be great. Thanks!
