hxcfe.exe Sector not found error
mikeyp
Post by mikeyp »
Hi Jeff
I'm getting an odd error when adding a file to a HFE image via command line.
To reproduce, I create a blank 1.44MB HFE image with HxCFloppyEmulator v2.1.24.1 called BLANK.HFE. I then use the following commandline to add any file and get the following output.
E:\SNES>HxCFloppyEmulator_soft\hxcfe.exe -finput:HxCFloppyEmulator_soft\BLANK.HFE -putfile:7za.dll
HxC Floppy Emulator : Floppy image file converter v2.0.2.1
Copyright (C) 2006-2018 Jean-Francois DEL NERO
under certain conditions;
libhxcfe version : 2.9.5.1
Input file : HxCFloppyEmulator_soft\BLANK.HFE
File Image: HxCFloppyEmulator_soft\BLANK.HFE
Checking HxCFloppyEmulator_soft\BLANK.HFE
File loader found : HXC_HFE (SD Card HxCFE HFE file Loader)
Loading HxCFloppyEmulator_soft\BLANK.HFE
file loader found!
File type : HXC_HFE - SD Card HxCFE HFE file Loader
Floppy interface mode : IBMPC_HD_FLOPPYMODE - PC Interface (1.44MB/HD Disk)
Number of Track : 84
Number of Side : 2
hxcfe_readSectorData : ERROR -> Sector not found ! track 0, side 1, sector 19,Sector size:512,Type:0
hxcfe_readSectorData : ERROR -> Sector not found ! track 0, side 0, sector 19,Sector size:512,Type:0
Put 7za.dll
Files size : 362496 Bytes
Create /7za.dll
Write HFE file HxCFloppyEmulator_soft\BLANK.HFE for the standalone emulator.
Floppy interface mode IBMPC_HD_FLOPPYMODE (PC Interface (1.44MB/HD Disk))
84 tracks written to the file
Stopping HxCFloppyEmulator...
Thanks again
Michael
Re: hxcfe.exe Sector not found error
You can ignore this error : This message come while the software try to detect if this is a 720KB/1.44MB or a 2.88MB image.
I should mask/hide it.
mikeyp
Post by mikeyp »
Excellent. Thank you. :)
