How to get voice from another bank ? HxC
EIIAttack
Post by EIIAttack »
Hello
I have a HxC SD emulator installed on bay 1 of my Emulator 2
and second bay is a 5" drive.
What I couldn't figure out is that , how to get a voice from another bank on a SD while you are in another bank ?
When I do that, EII trying to get it from drive B .
How to setup the HxC to act as second drive , and get a voice from a selected bank ?
That would be super helpful !
Re: How to get voice from another bank ? HxC
If you want to set the hxc drive to B, you need to change the HxC switches setting (ID1-A) and also change the second drive jumper settings to change it to drive A.
EIIAttack
Post by EIIAttack »
Jeff wrote: Thu May 30, 2019 11:14 am If you want to set the hxc drive to B, you need to change the HxC switches setting (ID1-A) and also change the second drive jumper settings to change it to drive A.
Hello Jeff thanks for the reply
So , does it mean you can get another voice from another bank requires that the bank you are looking at has to be at drive B ?
I really dont get it clearly .
Lets say I set the HxC to drive B , and machine should boot from there . And when I call for a voice , will it take it from B again .
I have a feeling this time it will search at A .
well , I am a bit confused about this .
Couldn't figure out how to get voice from SD card , while you are on another voice on same SD card
EIIAttack wrote: Thu May 30, 2019 11:37 pm
i don't know. This is a E-mu Emulator specific question, not directly related to the floppy emulator.
I just answered to this :
EIIAttack wrote: Tue May 28, 2019 12:03 pmHow to setup the HxC to act as second drive ,...
EIIAttack
Post by EIIAttack »
Jeff wrote: Thu May 30, 2019 11:47 pm
thanks , fair enough .
EIIAttack
Post by EIIAttack »
I just saw the section of the forum as EII , so I was expecting some guidance
maybe someone else can jump in to conversation .
thanks anyway
