I tried to do convert an adf-file to an hfe-file but i failed with this command:
hxcfe -finput:tbl_eon_party_ver_disk1.adf -foutput:tbl_eon_party_ver_disk1.adf.hfe conv:HXC_HFE
I tried to find out with "hxcfe --help" and finding information in the source code and duckduckgo but I failed.
Could please someone help me?
Cheers
Michael
convert adf to hfe with hxcfe - question
Re: convert adf to hfe with hxcfe - question
First a question : Do you have a specific need to use the command line tool ? Why you don't use the gui ?
I could not install the GUI on Debian with xfce because of some gnome dependencies as I remember.
Edit: I have found here same problem on ARM instead of AMD64 (my installation). A comment says "You need to do some apt-get to get the X11 devel library + some other stuff (i don't remember exactly which one.)" and that solved the problem.
I had just retried building the software with "make all".
Maybe someone can point me to the solution installing the GUI:
Here is a part of the error which appears with "make all"-command
g++ -o hxcfloppyemulator main.o utils.o main_gui.o msg_txt.o about_gui.o batch_converter_window.o floppy_dump_window.o floppy_infos_window.o license_gui.o log.o rawfile_loader_window.o sdhxcfecfg_window.o usbhxcfecfg_window.o cb_batch_converter_window.o cb_floppy_dump_window.o cb_floppy_infos_window.o cb_rawfile_loader_window.o cb_sdhxcfecfg_window.o cb_usbhxcfecfg_window.o cb_filesystem_generator_window.o filesystem_generator_window.o cb_edittool_window.o edittool_window.o microintro.o lzw.o pack.o rle.o hxcmod.o loader.o soft_cfg_file.o fileselector.o ../sources/thirdpartylibs/fltk/fltk-1.3.x/lib/libfltk.a ../sources/thirdpartylibs/fltk/fltk-1.3.x/lib/libfltk_images.a libhxcfe.so libusbhxcfe.so ../../../build/libhxcadaptor.a -lc -lm -ldl -lpthread -Wl,-rpath=. -lX11
/usr/bin/ld: ../sources/thirdpartylibs/fltk/fltk-1.3.x/lib/libfltk.a(Fl.o): relocation R_X86_64_32 against `.bss._ZL13first_timeout' can not be used when making a shared object; recompile with -fPICRe: convert adf to hfe with hxcfe - question
So the issue is solved ?mcguire2 wrote: Sat May 11, 2019 1:32 pm Edit: I have found here same problem on ARM instead of AMD64 (my installation). A comment says "You need to do some apt-get to get the X11 devel library + some other stuff (i don't remember exactly which one.)" and that solved the problem.
The '-' is missing before "conv".mcguire2 wrote: Sat May 11, 2019 1:17 am Hello,
The command should be :
hxcfe -finput:tbl_eon_party_ver_disk1.adf -foutput:tbl_eon_party_ver_disk1.adf.hfe -conv:HXC_HFE
Great thanks, Jeff. The hiven was missing. Now I could convert successfully. Solved
