how saves in gaming??
Mandarancino
Post by Mandarancino »
Hi guys, in a new user for Amiga 600 and 1200, on 1200 installed gotek Whit hxc firmware at last stable but i don't know Is possible save game, created by winuae an .adf empty and place on position 1 in gotek but now??
Example in monkey Island Is possible save? At every Moment of game?? Where Is the mode?
Re: how saves in gaming??
Mandarancino wrote: Sun Apr 07, 2019 8:20 am Hi guys, in a new user for Amiga 600 and 1200, on 1200 installed gotek Whit hxc firmware at last stable but i don't know Is possible save game, created by winuae an .adf empty and place on position 1 in gotek but now??
Sure it is possible (If the game offer this possibility of course ;) ) ! Just save and this should be ok. There is nothing to do on the emulator.
But be aware of this : Some games use special format or extra tracks to save the game progression. In these cases you may need to use the HFE format instead of ADF. Just use the HxC software to convert your ADF for these specials cases :
https://hxc2001.com/download/floppy_dri ... r_soft.zip
Mandarancino
Ah ok, in game wait the Moment of save.. ! Later try to convert my adf with program you link me!
Another question pls, in another gotek the boot some Is ok and some see me an error can't open the hxc.....cfg, how Is possibile??
Sorry for my basic english...
Mandarancino wrote: Sun Apr 07, 2019 11:43 am Another question pls, in another gotek the boot some Is ok and some see me an error can't open the hxc.....cfg, how Is possibile??
You may need to update the firmware :
Mandarancino
I have the last firmware stable now, in my First gotek work fine...
Mandarancino wrote: Sun Apr 07, 2019 12:17 pm I have the last firmware stable now, in my First gotek work fine...
Where do you see the error message ? On the amiga screen ?
Mandarancino
Yes put selector on 000 for the menu and at the screen on boot when the firmware try to enter in the program of selection for the .adf see errore...
Mandarancino wrote: Sun Apr 07, 2019 1:36 pm Yes put selector on 000 for the menu and at the screen on boot when the firmware try to enter in the program of selection for the .adf see errore...
Have you used the latest config file and file selector ? :
Mandarancino
I downloaded your zip but, how use this?
Mandarancino wrote: Sun Apr 07, 2019 6:26 pm I downloaded your zip but, how use this?
Copy Config_Files/Autoboot_mode/HXCSDFE.CFG and File_Selector/Amiga/AUTOBOOT.HFE to the root of the usb stick.
