ROBOFIL 310 and Gotekt USB FDD Emulator
BKs
Post by BKs »
i have read through some of the topics already, but i couldn´t find a solution to my problem.
In our Workshop we are currently using a ROBOFIL 310 mchine with a TEAC fd-235hf c929-u5 Floppy Disk Drive.
Since im renewing our IT infrastructure in the workshop i thought i could get rid of the floppy disks altogether.
So I looked up on google for a good solution and found the Gotek/ Yosoo SFR1M44-U100K Updated Version emulator.
Today i got my hands on it and tested it out immediately, but the ROBOFIL say "no floppy disk in hard drive A".
So i took a photo of the jumpers in the back and startet to search the internet about gotek jumpers.
The TEAC fd-235hf c929-u5 Floppy Disk Drive has the following jumper settings:
FG - 0V (FG)
DS - 10 (DS0)
SY - 34P (RY34)
HI - HS (HA)
Now im trying to do the same on the Gotek emuator, but i could find only 2/4 of the settings.
Gotek jumper settings:
JA (RY34)
S0 (DS0)
Now my question is, how can i get the other two connections?
HI - HS (HA) sets the density to auto
FG - 0V (FG) is the short between FDD frame and DC 0V (is this like PEN?)
Im using "USB Floppy Disk Manager 1.40i" to format my USB-Stick to 100x 720KB Virtual Floppys.
Thanks in advance!
Photos:
Gotek:
https://photos.app.goo.gl/owNZ62TGKH771FoV7
https://photos.app.goo.gl/Vpf4AmAs38WZKXKv5
TEAC:
https://photos.app.goo.gl/hCXBeoT7qb7CGeAg7
https://photos.app.goo.gl/E3bgLaNZknFTmyNQA
Re: ROBOFIL 310 and Gotekt USB FDD Emulator
I suppose that you don't have the HxC firmware on this gotek ? :
https://hxc2001.com/store
BKs
Post by BKs »
Not yet, im missing an 34-Pin to USb adapter or a pc with IDE.
I have sent a mail in my univerity maybe someone can help me out.
Otherwise i have found some on ebay.
Thank you for the reminder
BKs
Post by BKs »
I got my hands on an old PC with IDE and connected the gotek FDD to it.
Now i was searching for a flashing tutorial, but i realized that purchasing the gotek drive and an old PC seems not to be enough to keep going.
Am i right that i need the bootloader (10€) and some micro controller that i can solder to the gotek in order to flash the firmware?
Can someone tell me what else i need?
Thanks in advance!
Jeff_HxC2001
Post by Jeff_HxC2001 »
BKs wrote: Fri Mar 15, 2019 3:58 pm I got my hands on an old PC with IDE and connected the gotek FDD to it.
Thanks in advance!
You need to have a usb-serial ttl adapter. A FTDI cable is fine for example.
You can also use a usb usb cable to flash the drive but you will have to contact me to hxc2001 at hxc2001.com
