Empty disk image for the Sharp MZ-80K
minty
Post by minty »
Embolden by my success with the Sharp MZ-80A (which has 5.25" floppies, unlike the Quick Disks of the later Sharps), I thought I'd have a go on my MZ-80K - and I'm stuck.
Unlike the 80A, there's no disk images out there, so I'm in virgin territory. What I do know is that it's a standard shugart interface, with SDDS FM encoded floppies. The Sharp website says:
"A disc is divided up into 70 tracks of 16 sectors each to give a total capacity of 1120 sectors. One sector can contain 128 bytes of data to give an overall capacity of 140K, the figure quoted by Sharp. Tracks are numbered from 0 to 69 with track 0 nearest the outer edge of the disc. Sectors are numbered from 1 to 16. In the Sharp System all even numbered tracks are on the top face of the drive and all odd numbered tracks in the lower face ( when the disc is in the drive )."
( https://original.sharpmz.org/mz-80k/disk01.htm )
So from that, I've set up the HxCFloppyEmulator to make a 35 track, 2 sided floppy with 16 sectors per track and 128 bye sectors. All other settings are currently at the default.
When I format the blank disk, all looks good, I can see it moving through all the tracks (so I know my cables are fine, etc) and it's only when it reaches the end does it come up with a 'no ready' message. I can't do a DIR on the floppy after this. Any ideas?
Many thanks in advance, Tony
Re: Empty disk image for the Sharp MZ-80K
Please share the formatted image.
minty
Post by minty »
Sure! For reference it's a RevC device, running v1.8.2.40 firmware and I'm using v2.1.22.3 of the software. I note that sometimes the device makes two alarm noises and then seems to crash at the end of the format.
Thanks, Tony
formatted.zip
(14.37 KiB) Downloaded 961 times
minty wrote: Sat Feb 23, 2019 5:37 pm Sure! For reference it's a RevC device, running v1.8.2.40 firmware and I'm using v2.1.22.3 of the software. I note that sometimes the device makes two alarm noises and then seems to crash at the end of the format.
Thanks, Tony
Thanks. The disk format is definitively special : the sector header seems to be compatible but the data section seems to be different.
Have you something to read a working disk (kryoflux) ?
minty
Post by minty »
Sadly, I don't have anything to read it, but I'll ask around. Any pointers on what I'd need to image a single density FM disk?
Many thanks for your help so far! Tony.
minty
Post by minty »
Ah, looks like I've found someone with a system that can do this - but we don't have Kryoflux. Would Imagedisk and/or Teledisk be okay?
minty
Post by minty »
I got a friend to make me Kryoflux images of some example floppies, but the files are too large to upload here. Is it possible to send them (or a link to them) to you directly?
Cheers, Tony
minty wrote: Wed Mar 20, 2019 1:16 pm Hi Jeff,
Cheers, Tony
send me a link to hxc2001 at hxc2001.com
