flashing issue
s219800
flashing issue
Post by s219800 »
Hello, I have tried flashing a couple gotek with the HxC software and all went fine, but this time when I get to the part where I insert the USB stick for the software when the LDR screen is on, i get a flashing 004 message (flashes 4 times then pauses for 2 seconds).
This gotek is in an akai S950 right now. I have tried using the indexed mode and i get that error, tried the S950 config mode to no avail, I tried flipping the cable, I tried putting a jumper on s0 and tried without jumper.
I am using a FAT32 formatted usb micro stick with only the .CFG file on it
What am I doing wrong?
Re: flashing issue
Copy the latest upd file to the stick to finish the firmware installation.
s219800
Re: flashing issue
Post by s219800 »
oh yeah! worked as a charm
thanks jeff!
darq82
Re: flashing issue 003/004
Post by darq82 »
After uploading version 3.5.2.5.a, the 004 message appeared, then I tried with a few older versions and 003 was displayed.
Can you please help?
Thank you,
Darek
darq82 wrote: Fri Mar 12, 2021 1:52 pm Hi Jeff,
Thank you,
Darek
Retry with another USB stick and power supply.
darq82
Re: flashing issue
Post by darq82 »
Everything is fine, thanks a lot!
