Thomson *.fd single sided
gilles
Post by gilles »
When selecting a single sided *.fd image with a gotek (tested firmwares 3.1.23.1A and 3.1.31.1A) the image is loaded but Err is displayed (on the 7 segment screen).
size of tested image is 327680 bytes
(I took this image http://dcmoto.free.fr/programmes/3dfigh ... _to8fd.zip and 2 or 3 more)
HFE works correctly in the same unit for thomson (I'm porting the AUTOBOOT.HFE to TO9)
System type is on AUTO
Re: Thomson *.fd single sided
Tried and the file is working perfectly here. I suppose that you are using your file selector? The file extension in the cfg file need to be padded with space characters (0x20) when its length is less than 3 characters.
gilles
Post by gilles »
I'm using the fileselector and the 8.3 entry should be an exact copy of the 8.3 entry in the VFAT entry but I'm checking exactly what I have here.
gilles
Post by gilles »
padding seems correct in the 8.3 part:
00000480 4a 45 55 58 2d 54 7e 31 46 44 20 00 00 df 1a 00 |JEUX-T~1FD .....|
00000490 00 00 a4 1e 00 6a 65 75 78 2d 74 6f 37 2d 61 64 |.....jeux-to7-ad|
000004a0 61 70 74 65 73 00 00 00 00 00 00 00 00 00 00 00 |aptes...........|
000004b0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
but Size is probably not
I'm checking if it is my problem here.
yes the size is important too !
gilles
Post by gilles »
Yep, it was my problem.
I have only small size for name (8.3 + long filename) and address of 1st cluster so I did not store the size in the slot (I used a fixed value for HFE).
I now use 3 char that were in the long filename to store the size (16Mb max will be enough for floppy images).
FD are now loaded correctly in fileselector
