HxC SD Floppy Emulator Rev C, Amiga 1000 - Manager Freezes
lacaca
Post by lacaca »
I recently purchased and received the "HxC SD Floppy Emulator Rev C (Cased)" from Lotharek. It actually arrived two days ago, It is running the most current firmware (came this way) and I am trying to use the latest version of the HxC floppy emulator manager. This is all done on an Amiga 1000 with 512kb internal and a 1MB sidecar. The HxC is an external cased version, but I am running the floppy and power cable from it directly into the Amiga 1000 and removed the connection from the internal floppy drive. It is essentially DF0:
I converted a kickstart ADF (v1.3) to .hfe format and I have this set to STARTUPA.hfe. As you know, the Amiga 1000 first needs a kickstart boot disk as kickstart is not resident in a rom. Afterward, I can select any .hfe on the unit, soft reset, and it boots it. I have tested Workbench (and tested writing support) and it works fine. I have loaded some games and demos and they work fine.
Re: HxC SD Floppy Emulator Rev C, Amiga 1000 - Manager Freezes
it freeze at which point exactly ?
have you tried some older versions ? :
https://github.com/jfdelnero/HXCFE_file ... r/releases
