Single 'dash' on LED, No Boot after saving config in selector
displaced
Post by displaced »
I've got an HxC-flashed Gotek fitted internally on an Atari ST. It's using the Autoboot_mode CFG file with the Atari ST File selector.
HxC Firmware version 3.1.23.1a, Selector v1.89a
Games load and run absolutely fine, but I can consistently break the setup by doing the following:
  • Boot into the File Selector
  • Hit F3 to go into the settings menu
  • Turn on Eject at Power On
  • Exit settings menu
  • Hit F9 to save
  • Power off/on the system
At this point, the Gotek displays just a single - in the centre of the middle LED digit. The machine no longer sees the drive.
If I plug the USB drive into my computer and replace the HXCSDFE.CFG file with the original download, it then works correctly.
I've replicated this several flash drives, old and brand-new; generic and branded.
All files obtained from the HXCFEUSB_V3_1_23_1a beta firmware download ZIP.
Not sure if this is a known issue with the beta, but I'll try next with the WIP-version Selector and Firmware and report back.
Cheers,
Chris
Re: Single 'dash' on LED, No Boot after saving config in selector
The single - just mean that the image is ejected. press again both buttons to reinsert the image.
Since you have enabled "Eject at Power On" this is the normal behaviour.
displaced
Post by displaced »
Aaah! That makes sense - thank you!
I'm sure at some point I had it set up to return to disk 000 (the selector) after a reboot. I thought that was the setting to do so. I'll keep reading the docs and trying stuff!
(EDIT): Ah, of course -- I needed 'Load AUTOBOOT.HFE at power up' - sorted!
Cheers,
Chris
