Charmilles Roboform 22 EDM
skippysmt
Post by skippysmt »
Hello Again Jeff I Need some help please
I’m converting a RoboForm 22 that save to a disk, programmes and also has 3 software disk that need to read back into the machine if it crashes or the battery go flat.
I have done two latter machine and they work just fine.
I have copied all the disk with Kryoflux and have images of all 4 disk.
I can see all the files on the disk browser software fine when I put them in the machine I get a disk fault "directory not initialised” most of the time. I think it pin/software setting fault.
If I try and format the disk if formats all 80 sector then it does what I think is a disk search and comes up with no floppy fault.
The floppy drive in this machine is an fd235hf-a529 and I have sent you a photo of the pin setting to your FTP server and a date sheet for the drive.
It’s using pin 2 as disk change and 34 as ready and is set for DS0 but I think it could be using another pin also.
I have tried using custom setting but cannot find any information on what the difference is between disk changes 1, 2, 3 in yours new software. Is there a new up dated manual coming soon as there is a lot of new function now but no documents how to use them.
I await your help Skippy.
Re: Charmilles Roboform 22 EDM
Can you dump the disks with the kryoflux with the preservation raw format (*.raw) ? According to the dtc logs some sectors was bad...
skippysmt
Post by skippysmt »
i will do it this week as been overloaded with work
skippysmt
Post by skippysmt »
Uploaded the raw files for you to have a look at thank you
skippysmt
Post by skippysmt »
jeff have you had a chance to look at the files
skippysmt wrote: Tue Feb 12, 2019 9:58 pm jeff have you had a chance to look at the files
no not yet.
The images are perfects.
You can get the converted images into the dump samheath/rob22.zip file on the ftp server.
Nephor
Post by Nephor »
Sorry for offtopic, but I see, that you had been using (hope, that you still have) Roboform 22.
We have this machine for some time, but I think I don't have some technology files.
I there any chance, that you have copy of those, and you can send me them? Mainly I need CUAC/UCUAC.TEC
I'll be very grateful.
Best regards,
Sebastian.
