Mr. Jeff, Can I use your HxC software to convert hfe to img?
marctronixx
Post by marctronixx »
Mr. Jeff,
As title states, I have some hfe images due to the gotek i bought being setup to read hfe. now that I am successfully reading img files direct form omniflop, id like to find a way to convert these hfe images to img. i know you have a batch convert mode on your software, but didnt see if it was possible.
i hope I am not asking you something disrespectful. you have to pardon my ignorance!
if its not possible, no worries. Just wanted to ask.
Re: Mr. Jeff, Can I use your HxC software to convert hfe to img?
With the hxc software, open the hfe, export the image to the "IMG file (RAW Sector file format)" file type and change the file extension to "aka".
(the final file size should be 80*2*10*1024=1638400 bytes for S950 images)
marctronixx
since I use img, can I change it to IMG, or MUST I use aka?
thank you!!!
marctronixx wrote: Thu Dec 27, 2018 3:15 am since I use img, can I change it to IMG, or MUST I use aka?
thank you!!!
you can use "img" if you set the akai mode in the menu.
marctronixx
Thank your for your help sir. Much appreciated. Happy new year.
