Emulator lock feature
tooty
Post by tooty »
dear jeff,
your product has benefited us a lot still using old machines. thanks.
however, we have some risk/problem encountered that some busybody could have chance to touch the button to change the disk image. it will cause our machine parameters saved elsewhere or even the process stopped.
is it possible to realize the lock function if the operator dont want the others to change disk? what comes into my mind is to push both buttons to toggle lock/unlock.
best wishes.
wj
Re: Emulator lock feature
tooty wrote: Fri Dec 21, 2018 6:21 pm dear jeff,
best wishes.
wj
yes i can implement something like this. but the 2 buttons are already used to eject/insert the image disk.
tooty
Post by tooty »
great! maybe long press of one button can do...
looking forward to the new version.
thanks
tooty wrote: Sun Dec 23, 2018 1:52 pm great! maybe long press of one button can do...
thanks
i am thinking about an autolock feature: power up -> normal mode during 30 seconds -> auto lock -> long press to leave the auto lock.
tooty
Post by tooty »
Jeff wrote: Sun Dec 23, 2018 2:11 pm i am thinking about an autolock feature: power up -> normal mode during 30 seconds -> auto lock -> long press to leave the auto lock.
that's an very good idea.
i suggest to use the same way as we commonly use on many machine in the factory. in "setting mode", the display keeps blinking and no disk at all. once disk loaded(either select button pressed or auto load enabled), panel is locked. in the "disk loaded mode", long press of any button will eject the disk and it enters into setting mode.
tooty wrote: Tue Jan 15, 2019 3:01 am
What do you mean with "setting mode" ? You mean "disk image selection mode" ?
tooty
Post by tooty »
Jeff wrote: Tue Jan 15, 2019 10:55 am
yes, it is.
tooty wrote: Wed Jan 16, 2019 2:21 am
yes, it is.
ok will add the feature ! Stay tuned ! :D
