This may seem like a stupid question, sorry, but I will ask anyway... I've been away from my Amiga stuff for a long time, the last bit of activity was a few years ago when I got a Gotek drive and then later realized the HxC firmware was available for it and so purchased the bootloader for it.
The selection program runs on boot, or from the HD when DF0: is mounted with it, I can run HXCFEMNG. However, at least v1.85a that came with FW v3.1.32.1a seems to have no method to quit the program once you run it without a reboot.
Am I just missing something, or is it not possible to do some limitation?
Amiga selection program - run from HD?
Re: Amiga selection program - run from HD?
This is just not currently implemented. But this can be done easily, i just need to find time to work on thisn9yty wrote: Mon Dec 17, 2018 11:26 pm This may seem like a stupid question, sorry, but I will ask anyway... I've been away from my Amiga stuff for a long time, the last bit of activity was a few years ago when I got a Gotek drive and then later realized the HxC firmware was available for it and so purchased the bootloader for it.
Done !Jeff wrote: Tue Dec 18, 2018 12:47 am This is just not currently implemented. But this can be done easily, i just need to find time to work on this.
EDIT : Link removed Please use the stable version
Super.
It is possible multitasking version program?
It is already "multitasking" friendly. Workbench still there when the hxc file selector is running.
Press "Left Amiga" + "N" to switch to the workbench and "Left Amiga" + "M" to switch back to the manager (or any others "system friendly" fullscreen applications).
Btw about multitasking, try this version instead : it has a better screen handling.
Reminder :
Press Left-Amiga+N keys to switch to the Workbench.
Press Left-Amiga+M keys to switch back to the HxC File selector (or any other Workbench friendly full screen software...).
You can drag/scroll the HxC File selector with the upper bar.
Reminder :
Stable version released :
https://github.com/jfdelnero/HXCFE_file ... ctor_V1_89
https://github.com/jfdelnero/HXCFE_file ... anager.zip
HxC Floppy Emulator file selector Version 1.89
Amiga -> Better multitasking/Workbench compatibility/support :
-> Don't "overtake"/hand-initialize the screen anymore : Let the system initialize the bitplane and just use it.
-> Don't reboot anymore the system but just exit the file selector if we are not track-loaded.
-> Don't lockup the system anymore in case of error if we are not track-loaded.
With these modifications the file selector is now more "Workbench-friendly".
Amiga Workbench tips and tricks :
Press Left-Amiga+M keys to switch back to the HxC File selector.
You can drag/scroll the HxC File selector screen with the upper bar.
Thank you very much, this is a huge benefit to me. I used it last night to help set up CFD and FAT95 on an old HD install, it was nice to be able to build the ADF containing those files on the Mac using xdftool, copy them over to USB, and then dynamically add them to the slot list on an already running Amiga system. Worked perfectly!
Would this process be the same on a Windows machine instead of Mac?
