GOTEK Pushbuttons with HxC Firmware??
ldkraemer
Post by ldkraemer »
Jeff,
I'm in the process of installing the HxC Firmware on my GOTEK. It is a 3 - 7 Segment LED with two Pushbuttons.
I've looked over the Forum postings, and see no reference as to what the two GOTEK Pushbuttons will do when
flashed with the HxC Firmware.
The Original HxC units use 3 Pushbuttons (Previous, Enter, Next). Should I add the additional Pushbutton
on the GOTEK across the JA Jumper for the SELECT feature? Also that functions do the two existing GOTEK
Pushbuttons control with the HxC Firware? Still control Units Increment and Tens Increment, and Both for
Hundreds Increment?
THANKS.
Larry
Re: GOTEK Pushbuttons with HxC Firmware??
ldkraemer wrote: Tue Dec 04, 2018 5:02 pm The Original HxC units use 3 Pushbuttons (Previous, Enter, Next). Should I add the additional Pushbutton
Hundreds Increment?
No : Left button = Previous, Right button = Next.
The Enter/select button is optional : There is an auto select timeout.
