HxCFloppyEmulator Automated File into disk IMG
chrisf
Post by chrisf »
Hi
Im putting a single file into a disk image using the disk browser .smc files to use on my snes super wildcard , the process is going to take an age doing this manually :(
Is there a way to automate the process from a folder full of .smc files and create a .img file containing 1 smc file inside 1.6mb fat12 .img file ?
thanks
Re: HxCFloppyEmulator Automated File into disk IMG
chrisf wrote: Tue Dec 04, 2018 5:01 pm Hi
thanks
you can use the batch converter.
chrisf
Post by chrisf »
hi
thanks for your reply
there is no option in the batch converter to output to .img
i tried a few different formats and they didn't work
what format would you suggest ?
thank you
chrisf wrote: Wed Dec 05, 2018 1:25 am hi
thank you
choose raw file as output format.
chrisf
Post by chrisf »
Hi
Thanks for your response
That does not work either it creates an .img file but if you then try and open it with floppy disk file browser it says
No DOS Image Loaded !
Im unsure how this would work as an .smc file is not a disk image ?
im wanting to create a dos floppy image with an .smc on it
thanks
chrisf wrote: Thu Dec 06, 2018 2:54 am Im unsure how this would work as an .smc file is not a disk image ?
Yes sure, but the software should automatically create an dos image with the smc file.
please share one of them.
chrisf
Post by chrisf »
hi i have attached a file
thanks
test.zip
(111.67 KiB) Downloaded 457 times
This supersized img is valid... if you keep it in HFE format for the HxC emulators.
What are you trying to do exactly ? Are you using it with the hxc floppy emulators ?
chrisf
Post by chrisf »
hi
Im using it on a gotek with hxc
The problem is the output format for a super wildcard needs to be 1.44 mb or 1.6mb dos format , so im unsure as to why this program is creating supersize images when the files going on are 1.50mb approx max ?
Can the output format for smc in the batch converter be changed to 1.6mb dos .img ? as that's all you would ever need for smc files ?
creating this format manually with the disk browser works fine
thanks
This is to support SMC > than 1.6MB without splitting them.
Have you tried the HFE files ?
chrisf
Post by chrisf »
hi
i tried the hfe file , it just starts loading then shows an error on the tv screen on the wildcard
the wildcard doesn't support higher capacity drives that an normal pc one , so the bigger roms (smc) have to be split
chrisf wrote: Fri Dec 07, 2018 10:36 pm hi
Which emulator/firmware are you using ?
chrisf
Post by chrisf »
gotek with hxc
chrisf wrote: Sat Dec 08, 2018 5:19 pmgotek with hxc
Your are not in my list. Where did you get gotek ?
chrisf
Post by chrisf »
hi
it was bought from ebay a while ago
the problem im having is the HxCFloppyEmulator program and the way it handles smc files in the batch converter ? not the gotek ?
thanks
