Commodore 64 - .d64 format loader issue
shattered
Post by shattered »
I have found a bug in GCR encoder used by d64 loader (bit order is reversed and track number is off by one). I have not tested the fix on a real C64, but HFE images converted with "hxcfe -conv:HXC_HFE" load OK in emulation (MAME). Please review this diff to svn HEAD:
--- HxCFloppyEmulator/libhxcfe/trunk/sources/tracks/gcr_track.c	(revision 1660)
+++ HxCFloppyEmulator/libhxcfe/trunk/sources/tracks/gcr_track.c	(working copy)
@@ -111,10 +111,10 @@
 		nongcrcode=nongcrpart[l];
-		if(!((nongcrcode>>shift)&0xF))
+		if(!((nongcrcode>>(4-shift))&0xF))
-			gcrcode=gcrencodingtable[(byte>>shift)&0xF];
+			gcrcode=gcrencodingtable[(byte>>(4-shift))&0xF];
 			for(j=0;j<5;j++)
@@ -139,7 +139,7 @@
 		else
 		{//non gcr - direct copy
-			quartet=(byte>>shift)&0xF;
+			quartet=(byte>>(4-shift))&0xF;
 			for(j=0;j<4;j++)
@@ -253,7 +253,7 @@
 				j++;
 				tempdata[j]=l;    // Sector
 				j++;
-				tempdata[j]=tracknumber;  // Track
+				tempdata[j]=tracknumber + 1;  // Track
 				j++;
 				tempdata[j]=0xA1;  // Format ID byte #2
 				j++;
Re: Commodore 64 - .d64 format loader issue
Thanks, the modifications are committed.
I think that this is the first feedback i got about this code/feature since 2009. :o
shattered
Post by shattered »
Thanks, there's more to come - I am trying to write .d64 to disks using a Supercard Pro setup, having lots of fun :)
Found an off-by one, this causes inner tracks to be too long:
Index: HxCFloppyEmulator/libhxcfe/trunk/sources/tracks/gcr_track.c
--- HxCFloppyEmulator/libhxcfe/trunk/sources/tracks/gcr_track.c (revision 1670)
@@ -284,7 +284,7 @@
                                tempdata[j++] = 0x00;  // $00 ("off" bytes)
-                               for(k=0;k<9;k++) // sector gap
+                               for(k=0;k<8;k++) // sector gap
                                        tempdata[j]=0x55;
                                        tempnongcr[j]=0xFF;
+ there's dead code in scp_writer.c -- "if( floppy->tracks[0]->floppyRPM > 350 && floppy->tracks[0]->floppyRPM < 340)"
shattered
Post by shattered »
It's working now -- tested on a real C64 and 1451 drive, using "index" writing mode.
SCP software expects C64 images to be 96tpi, so I'm doubling every track (this is interpreted as image with half tracks, which probably helps -- my drive is 96tpi). Setting number of heads is apparently not critical -- SCP software expects C64 images to be single sided anyway -- but length of second gap is critical.
--- HxCFloppyEmulator/libhxcfe/trunk/sources/loaders/scp_loader/scp_format.h	(revision 1670)
+++ HxCFloppyEmulator/libhxcfe/trunk/sources/loaders/scp_loader/scp_format.h	(working copy)
@@ -375,8 +375,8 @@
 	uint8_t  start_track;
 	uint8_t  end_track;
 	uint8_t  flags;
-	uint8_t  RFU_0;
-	uint8_t  RFU_1;
+	uint8_t  bit_cell_width;
+	uint8_t  number_of_heads;
 	uint8_t  RFU_2;
 	uint32_t file_data_checksum;
 }scp_header;
--- HxCFloppyEmulator/libhxcfe/trunk/sources/loaders/scp_loader/scp_writer.c	(revision 1670)
+++ HxCFloppyEmulator/libhxcfe/trunk/sources/loaders/scp_loader/scp_writer.c	(working copy)
@@ -287,6 +288,8 @@
 			case C64_DD_FLOPPYMODE:
 				scph.disk_type = 0x00;
+				tracknumber *= 2;
+				scph.end_track = tracknumber - 1;
 				break;
 			case S950_HD_FLOPPYMODE:
@@ -308,12 +311,26 @@
 		if(floppy->tracks[0])
-			if( floppy->tracks[0]->floppyRPM > 350 && floppy->tracks[0]->floppyRPM < 340)
+			if( floppy->tracks[0]->floppyRPM > 350 /* && floppy->tracks[0]->floppyRPM < 340 */)
 				scph.flags |= 0x04;
+		switch (floppy->floppyNumberOfSide)
+		case 1:
+			scph.number_of_heads = 1;
+			break;
+		case 2:
+			scph.number_of_heads = 0;
+			break;
+		default:
+			break;
 		scph.version = 0x09;
 		imgldr_ctx->hxcfe->hxc_printf(MSG_DEBUG,"SCP_libWrite_DiskFile : Flags=0x%.2X Disktype=0x%.2X NumberOfRevolution=%d Version=%d NbTrack=%d NbSide:%d",scph.flags,scph.disk_type,scph.number_of_revolution,scph.version,floppy->floppyNumberOfTrack,floppy->floppyNumberOfSide);
@@ -344,7 +361,10 @@
 			else
-				write_scp_track(f,floppy->tracks[i]->sides[0],&track_checksum,i,scph.number_of_revolution);
+				if (floppy->floppyiftype == C64_DD_FLOPPYMODE)
+					write_scp_track(f,floppy->tracks[i>>1]->sides[0],&track_checksum,i,scph.number_of_revolution);
+				else
+					write_scp_track(f,floppy->tracks[i]->sides[0],&track_checksum,i,scph.number_of_revolution);
 			file_checksum = file_checksum + track_checksum;
@@ -284,7 +284,7 @@
 					tempdata[j]=0x55;
 					tempnongcr[j]=0xFF;
shattered wrote: Fri Nov 02, 2018 8:17 pm It's working now -- tested on a real C64 and 1451 drive, using "index" writing mode.
@@ -375,8 +375,8 @@
 	uint8_t  end_track;
 	uint8_t  flags;
-	uint8_t  RFU_0;
-	uint8_t  RFU_1;
 	uint8_t  RFU_2;
 }scp_header;
@@ -287,6 +288,8 @@
+				tracknumber *= 2;
 				break;
 				scph.flags |= 0x04;
+		case 1:
+			break;
+		case 2:
+			break;
+		default:
+			break;
 			else
+				else
@@ -284,7 +284,7 @@
 					tempdata[j]=0x55;
 					tempnongcr[j]=0xFF;
Thanks a lot ! Will push the modifications to the repository.
