Commodore PET 8050 .d80 image conversion
Pitou
Post by Pitou »
I'm trying to convert a .d80 disk image to .scp, to be able to write using my supercard pro.
HxC software can open .d64 files but gives an error for .d80.
Is it possible to do that at this point?
Thank you.
Pitou!
Re: Commodore PET 8050 .d80 image conversion
Pitou wrote: Mon Oct 01, 2018 8:46 pm Hello,
Thank you.
Pitou!
but what is a ".d80" ? a raw sector floppy image ?
Pitou
Post by Pitou »
Yes I think so.
You can refer to this paper for the definition.
https://ist.uwaterloo.ca/~schepers/formats/D80-D82.TXT
Thank you.
Pitou!
Pitou wrote: Tue Oct 02, 2018 3:21 pm Yes I think so.
Thank you.
Pitou!
This drive use a commodore sector format which isn't currently supported by the software. Later maybe !
