hfe compability
Kna
hfe compability
Post by Kna »
does the hxc-flashed usb gotek drive and the sd hxc drive (lotharek) read the same *.hfe-files, or do they need differently formatted files?
Im thinking specifically for emax 1.
Re: hfe compability
Kna wrote: Thu Sep 13, 2018 2:53 pm Hi,
yes why ?
Kna
Re: hfe compability
Post by Kna »
The emax library is freely available on net in *.hfe format. This works with the sd floppy emulator, was just wondering if the same files would work on a usb gotek emulator. But they do need different formatting, i take it?
Re: hfe compability
Kna wrote: Fri Sep 14, 2018 10:12 am The emax library is freely available on net in *.hfe format. This works with the sd floppy emulator, was just wondering if the same files would work on a usb gotek emulator. But they do need different formatting, i take it?
the same files should work with the same formatting.
Kna
Re: hfe compability
Post by Kna »
Ok, great. Thanks Jeff! :)
giorgione
Re: hfe compability
Post by giorgione »
Buonasera
scusami puoi indicarmi dove trovare la libreria emax in rete formato .hfe ?
Grazie
