Atari 1040STF and gotek emu
XLR-VIII
Post by XLR-VIII »
Hey Guys! I’m a little stuck here... I purchased a gotek drive off of eBay to install into my Atari ST 1040F. I put jumpers on M0 & S0 inserted flash drive into unit with the config file and “autoboot”.
It boots up to the user interface floppy manager where I can select my roms, however when I load the selected file it will restart and boot back up into the floppy manager again I can’t get it to load anything else.
Sticker on the unit says
HxC#245
Retronic Design
USB HxCFloppyEmulator v3.0.8.2a
Let me know what I not doing correct...
Re: Atari 1040STF and gotek emu
Update the firmware (and all others stuff) :
XLR-VIII
Post by XLR-VIII »
Results are the same.... :?
Only difference is the Firmware ver on the bottom left of the screen says FW v3.1.30.1a
XLR-VIII wrote: Mon Sep 10, 2018 11:31 am Results are the same.... :?
Have you updated the AUTOBOOT.HFE and the Config file aswell ?
(BTW : Remove the "MO" Jumper !)
XLR-VIII
Post by XLR-VIII »
I do have the updated HXCSDFE.CFG and AUTOBOOT.HFE files. Jumper is now removed :)
I noticed when I power on the ST it will display "000" then when the file selector boots it shows dashes "= = =".
When I execute a rom to run it will flash "001" quickly followed by "Err" then "000" and brings me back to the file selector.
XLR-VIII wrote: Mon Sep 10, 2018 8:04 pm I do have the the updated HXCSDFE.CFG and AUTOBOOT.HFE files. Jumper is now removed :)
I noticed when I power on the ST it will display "000" then when the file selector it shows dashes "= = ="
When I select a rom to run it will flash "001" followed by "Err" then "000" and brings me back to the file selector.
Ok then the problem is probably the file image you are trying to load.
What is this file image ?
