Emax problem 2.0
Lostatom
Emax problem 2.0
Post by Lostatom »
I have had my Emax 1 for a while now and got it working with the help of this forum. It has worked without any problems until a few days ago. It started saying Disk Not Formatted on boot-up. I haven't changed a thing and only used the two usb keys I have always used. Now I can't get it to work with any of the disks. It just says Disk Not Formatted.
Does anyone have any suggestions as to what the problem could be?
Re: Emax problem 2.0
Lostatom wrote: Sun Sep 02, 2018 5:57 pm Hi,
Have you tried to reinstall the images & config file from the quickinstall archive ?
Lostatom
Post by Lostatom »
Sorry for this very late answer.
I havent´t tried that and I think I have completely forgotten how I did it in the first place. I will have to spend some time trying that out.
What do you mean by quickinstall archieve?
thanks
Lostatom wrote: Thu Jan 03, 2019 11:58 pm Sorry for this very late answer.
thanks
some clean emax images can be found into this archive :
Lostatom
Post by Lostatom »
Again, late answer. Sorry. The problem was solved when I unplugged the cable connecting the drive and plugged it back in...
