.STX to HFEv3 problem
RobyF
Post by RobyF »
Hello, i made an image of a protected floppy perfectly working in Hatari (falcon setup) and in steem (well, it bomb like on real ste and physical floppy, but that's correct, since it search for dsp) and i'm trying to convert to hfev3 without luck. FloppyEmulator soft doesn't produce any file. I'm using latest version downloadable from the web page. Any help is appreciated.
Ps: sorry for my english
Re: .STX to HFEv3 problem
RobyF wrote: Fri Aug 17, 2018 9:15 am Hello, i made an image of a protected floppy perfectly working in Hatari (falcon setup) and in steem (well, it bomb like on real ste and physical floppy, but that's correct, since it search for dsp) and i'm trying to convert to hfev3 without luck. FloppyEmulator soft doesn't produce any file. I'm using latest version downloadable from the web page. Any help is appreciated.
And where can be found this image ?
Which emulator are you using ?
RobyF
Post by RobyF »
The image is made by me with pasti of an original copy protected floppy disk. I'm using a gotek unit, with 3.1.30.1a firmware. Floppy Emulator soft (2.1.11.1) create hfe and hfev2 image files ok, but copy protection check fail, so i tried hfev3 but it doesn't create any file. If you want to take a look at the stx image this is the link, thank you!
https://drive.google.com/file/d/1mbIeTf ... sp=sharing
RobyF wrote: Fri Aug 17, 2018 11:43 pm The image is made by me with pasti of an original copy protected floppy disk. I'm using a gotek unit, with 3.1.30.1a firmware. Floppy Emulator soft (2.1.11.1) create hfe and hfev2 image files ok, but copy protection check fail, so i tried hfev3 but it doesn't create any file. If you want to take a look at the stx image this is the link, thank you!
issue confirmed. will debug this.
RobyF
Post by RobyF »
Thank you!!
RobyF wrote: Sat Aug 18, 2018 8:24 amThank you!!
Try to replace the dll with this one :
https://hxc2001.com/vrac/libhxcfe.dll.zip
RobyF
Post by RobyF »
Now it convert the file without problem :). Sadly the copy protection check (hidden security track on physical floppy) fails again, asking to insert floppy disc in drive a... Is there some hope that in the future this kind of protection can be replicated in the converted hfe image?
Thank you again for your work!!
RobyF wrote: Mon Aug 20, 2018 2:05 pm Now it convert the file without problem :). Sadly the copy protection check (hidden security track on physical floppy) fails again, asking to insert floppy disc in drive a... Is there some hope that in the future this kind of protection can be replicated in the converted hfe image?
The copy protection should already pass. But the fix in the dll wasn't "good". I have fixed the thing this morning. i hope to make a pre release this week.
RobyF
Post by RobyF »
Great! This little software it's the only reason that i can't replace the floppy disc device with a gotek one.
RobyF
Post by RobyF »
Hello, do you have any news? Thank you
RobyF
Post by RobyF »
Sadly it doesn't work, it's still request the original floppy :(
RobyF wrote: Wed Oct 24, 2018 5:04 pm Sadly it doesn't work, it's still request the original floppy :(
ok will have to test it on my STE.
RobyF
Post by RobyF »
Hello, any news?
RobyF wrote: Mon Mar 18, 2019 10:20 amHello, any news?
No i completely forgot this.
and i have only a STE so this will probably don't work here ?
