Getting Sound files to load from QuickInstall_FloppyDiskImage
prodigy
Post by prodigy »
I have a Gotek programmed with HXC firmware HXCFEUSB_V3_1_23_1a.upd
I'm running in Normal mode - and the OS loads without having to Rename the HFE files like this : DSKA0000.HFE
As I am not running in index mode.
So I copied the files directly from QuickInstall_FloppyDiskImages - All works fine
Apart from one thing, there are some sound files included in SDHxCFE_Ensoniq_EPS.zip
CLARINET.hfe
ORGAN-V1.hfe
STRINGS.hfe
SYNBASS-.hfe
TRUMPET.hfe
TRUMPVAR.hfe
WOODFLUT.hfe
WOODWIND.hfe
Try as I might I cannot find anyway to load these - Any help would be appreciated as currently I have no sound library at all.
Loading these would give me a head start.
Re: Getting Sound files to load from QuickInstall_FloppyDiskImage
I am not sure to understand the issue : You can't select the image on the emulator or have you a problem when trying to load it on the synth ?
Which synth have you ?
prodigy
Post by prodigy »
Sorry - it's for the Ensoniq EPS 16+ ... I can't see them from load window of the EPS -they just don't show up ... but they are on the USB stick
prodigy wrote: Wed Aug 15, 2018 11:30 pm Sorry - it's for the Ensoniq EPS 16+ ... I can't see them from load window of the EPS -they just don't show up ... but they are on the USB stick
So you are probably in indexed mode. Remove the CFG file from the stick.
prodigy
Post by prodigy »
Hi Jeff, removed the CFG file - still couldn't get them to work
but I did get WBOY101.hfe & WBOY103.hfe to work
perhaps the sound files that wont show up are for the EPS classic ?
Any way not to worry I have few sounds to play with now.
