Atari ST Supported File Formats
ikklepaul
Post by ikklepaul »
Can anyone confirm which file formats are supported by the HxC firmware.
I have just received my Gotek and believe it has flash floppy preinstalled.
I have downloaded the HxC Manager which is working but unable to load .MSA files on .ST files
Does the HxC support MSA file format? before i go down the whole process of purchasing a license and flashing.
Also in regards to flashing I have seen two methods one using a serial interface and one using a usb
https://www.youtube.com/watch?v=yUOyZB9cro4
Will the usb method work for flashing the Gotek with HxC?
I'm hoping HxC will bring with it support for MSA so I don't have to convert my collection
Paul
Re: Atari ST Supported File Formats
ikklepaul wrote: Mon Jul 23, 2018 10:33 am Does the HxC support MSA file format? before i go down the whole process of purchasing a license and flashing.
Yes though the HFE format. Use the batch converter to convert automatically the collection.
ikklepaul wrote: Mon Jul 23, 2018 10:33 am Will the usb method work for flashing the Gotek with HxC?
yes - indirectly. But i prefer that you use the standard serial method.
ikklepaul wrote: Mon Jul 23, 2018 10:33 am I'm hoping HxC will bring with it support for MSA so I don't have to convert my collection
Not right now.
Use the batch converter to automatically convert the whole collection. Your PC will do the job once, not you ;)
