Roland SD-35 MIDI Module
appiah4
Post by appiah4 »
I bought a Roland SD-35 MIDI module and I want to replace its floppy drive with a Gotek unit flashed with the HxC firmware. Could anyone please point me towards how to set up the unit before placing it in this MIDI module?
Re: Roland SD-35 MIDI Module
appiah4 wrote: Wed Jul 18, 2018 6:21 pm I bought a Roland SD-35 MIDI module and I want to replace its floppy drive with a Gotek unit flashed with the HxC firmware. Could anyone please point me towards how to set up the unit before placing it in this MIDI module?
Set the jumper to S0, and use the Shugart interface mode.
You can use Dos DD preformatted images
appiah4
Post by appiah4 »
Many thanks, time to order a black gotek :)
HugoFeerst
Post by HugoFeerst »
appiah4 wrote: Tue Aug 14, 2018 9:56 am Many thanks, time to order a black gotek :)
Hi, have you got your SD-35 up and running with the Gotek yet? I'm in a similar situation re: my SD-35 and would like to know if it all worked out fine for you.
Hugo
HugoFeerst wrote: Sat Nov 10, 2018 10:38 pm
Hugo
Yes the HxC Gotek is compatible with the SD-35.
