ASR-10 Quick install images - "No disk Directories" error when trying to format an image
s_a_p
Post by s_a_p »
I found and have used the Ensoniq image utility, and have been able to boot from the image created from that utility. I then grabbed the quick start drive images and copied them to the SD to have blank "floppies" to write samples to. However, when I try to access or format them, I get a "No Disk Directories" error. Any idea what this means?
s_a_p
Re: ASR-10 Quick install images - "No disk Directories" error when trying to format an image
Post by s_a_p »
Thinking it was something wrong with the quick start images, I took the working system disk and copied it 30 times. I then renamed them ASRDSK0-29. Now, when I try to format the disk, it all goes well until I hit "YES" to format the disk, and then the display on my lotharek drive display changes-
It shows the following text:
T:000/080WES0
This is the third lotherek sd drive Ive owned and Ive never seen it display this message while writing to the drive or formatting. I do not hear it click or make any progress, and finally the ASR shows a message of FILE OPERATION ERROR.
yes this message mean that the emulator doesn't understand the incoming write sector. This is maybe because you are formatting with the wrong density/bitrate. What is the hfe file size ?
s_a_p
Post by s_a_p »
Hi Jeff- Thanks for responding. Ive tried several different file sizes in this. Im using the EnsoniqEFE2HFE utility. Ive only had luck with the ASR1600 batch file and it generates ~4mb hfes. Im able to boot from these, but not able to format or save to them. I also tried the quick start images which were ~3.5mb in windows XP.(I spun up a vm to try a few of the older ensoniq tools) these dont really do much for me at all.
please share the images, i will check them.
s_a_p
Post by s_a_p »
Jeff wrote: Sun Jul 15, 2018 10:48 am please share the images, i will check them.
Thanks Jeff! Here they are:
https://drive.google.com/drive/u/0/fold ... sdeH99iCkd
This should be public for anyone that has the link. Let me know if you cannot access them.
DSKA0000.HFE is in PC HD interface mode, which is correct for the ASR10
ASRDSK0.hfe & ASR1600_IMG.hfe are in shugart mode , which is NOT correct.
Try this : Remove the SDCard, press select to enter the menu -> Interface Cfg -> choose the PC HD interface mode. exit the menu and retry.
s_a_p
Post by s_a_p »
Jeff wrote: Wed Jul 18, 2018 5:23 pm DSKA0000.HFE is in PC HD interface mode, which is correct for the ASR10
I will try this ASAP. Thank you for your help here Jeff! You've helped me several times now- I would gladly donate to a patreon or paypal account for your efforts. do you have one?
s_a_p wrote: Thu Jul 19, 2018 4:15 am
Thanks. I am in France : I can't legally take money from paypal or patreon without invoicing you.
If you want you can get one (or some) hxc license for gotek : https://hxc2001.com/store
