Thomson TO8 Gotek configuration
Knabice
Post by Knabice »
Hi all,
Need some help to config my gotek to work on Thomson TO8
- Gotek is flashed successfuly with HXCFEUSB_V3_1_23_1a.UPD
- Jumper is on S0
- Gotek is plugged inside a floppy drive CD90-352, ribbon twisted (if not i can't see drive)
- In the settings i changed :
Interface : SHURGARD
Family : Thomson
Gotek led is always ON
The same CD90-352 with mechanichal drive instead of gotek is working and can read real floppy.
Tested some .fd or .sap or .hfe images nothing works, like no disk inserted
I am surely missing someting.
Sorry for my bad English, i'm French and we can speak French if its better for you :)
Thanks in advance
Re: Thomson TO8 Gotek configuration
Knabice wrote: Fri Jul 13, 2018 4:47 pm
The floppy image appears to be loaded by the emulator, but the machine can't read the disk.
The Gotek green LED is permanently lit (no flashing)
The floppy ribbon is probably connected to the wrong way. Try to reconnect it to the other way.
Explanation : A wrongly connected floppy ribbon force the drive selection by short-circuiting the floppy signals to the ground, and make the selection LED always lit. Of course the machine can't communicate with the emulator in such situation.
Be aware that with some machines the floppy ribbon coloured wire is NOT the pin 1 !
Knabice
Post by Knabice »
Thank you ! it's working.
The ribbon was well plugged the first time, but i did not change the settings and the drive was not detected.
I tried to reverse the ribbon and the drive was detected but the led was always on.
So i started to modify the settings with no luck.
So no twist with the ribbon, and Interface : SHUGART, Family : Thomson in the settings.
.fd and .hfe loaded successfully, but i find the loading time very long compared to real floppy, is there settings to modify ?
Thank you Jeff
Knabice wrote: Sat Jul 14, 2018 1:09 pm .fd and .hfe loaded successfully, but i find the loading time very long compared to real floppy, is there settings to modify ?
Please format the hfe with the machine and share it here, i will check if the parameters in the hxc softwares (gap3, skew, interleave...) are fine
Knabice
Post by Knabice »
Tried the same game in .fd and .hfe format
HFE format is way faster to load than .fd
attached file :
gotek_to8.zip
(59.37 KiB) Downloaded 843 times
Content :
original fd image
same fd image initialized with the machine
hfe image converted from original fd image and initialized with the machine
Formatting the .fd was smooth from track 01 to 80
Formatting the .hfe was less smooth, some stops and gaps
EDIT : Hey mais j'ai vu q'autres topics en Français, j'aurais pu démarrer en Français ! :wink:
C'est mieux pour les FD avec ce firmware ? :
https://hxc2001.com/download/floppy_dri ... CUSBFE.UPD
Knabice
Post by Knabice »
Oui :D
Les .fd et les .hfe se chargent à la même vitesse maintenant.
Merci
Knabice wrote: Sun Jul 15, 2018 11:51 am Oui :D
Merci
Parfait !
