Hey Jeff! Someone pointed out to me that you can't convert from DMK (or the other TRS-80 format) to SCP and back to DMK (or from a TRS-80 SCP image to DMK). The conversion ends up with the wrong number of tracks and their locations are off.
You can do a simple test yourself by converting the attached DMK disk image to SCP and back to DMK.
DMK support
DMK support
- 3ld.zip
- (93.58 KiB) Downloaded 1049 times
Re: DMK support
yes, the double step mode seems to be enabled. i will check this.JimDrew wrote: Thu Jul 12, 2018 8:28 pm Hey Jeff! Someone pointed out to me that you can't convert from DMK (or the other TRS-80 format) to SCP and back to DMK (or from a TRS-80 SCP image to DMK). The conversion ends up with the wrong number of tracks and their locations are off.
Re: DMK support
Hey Jeff! Did you ever get a chance to look into this issue with the stepping?
Re: DMK support
This is now fixed on the repository. But can you check that the converted image is valid ? :JimDrew wrote: Fri Aug 10, 2018 8:17 am Hey Jeff! Did you ever get a chance to look into this issue with the stepping?
https://hxc2001.com/vrac/3ld_dmk.scp
Re: DMK support
Sorry... just saw your response! I will check it!
Re: DMK support
Converted disk works great. Where is the repo that has the latest version of HxC?
