S950 2.25MB disk images - is this possible?
vout
Post by vout »
I have seen this question asked before but without any definitive answer - Is it possible to create 2.25MB disk images that can save the fully expanded S950 memory on a single hfe image?
lasscimmiabeat
Re: S950 2.25MB disk images - is this possible?
Post by lasscimmiabeat »
some feedback??? :?:
lasscimmiabeat
do u try a createa image?
lasscimmiabeat
vout wrote: Tue Jul 03, 2018 12:55 pm I have seen this question asked before but without any definitive answer - Is it possible to create 2.25MB disk images that can save the fully expanded S950 memory on a single hfe image?
@vout can you try
lasscimmiabeat
@vout @jeff some feedback?
lasscimmiabeat wrote: Tue Oct 20, 2020 3:12 pm @vout @jeff some feedback?
On the emulator : yes. Does the S950 support this ? : Probably not.
