SD HxC Rev C- Gerber Board Outline
TRSguy
Post by TRSguy »
I am trying to get a couple SD HxC Rev C boards made for my TRS80s and noticed that there does not appear to be a "board outline" gerber file in the listing of gerber files. This is required for the online board houses I was looking at. This seems to be a pretty simple file and I was wondering if someone has or can direct me to a file I can use as the board outline?
Re: SD HxC Rev C- Gerber Board Outline
TRSguy wrote: Wed Jun 20, 2018 6:13 pm I am trying to get a couple SD HxC Rev C boards made for my TRS80s and noticed that there does not appear to be a "board outline" gerber file in the listing of gerber files. This is required for the online board houses I was looking at. This seems to be a pretty simple file and I was wondering if someone has or can direct me to a file I can use as the board outline?
will check but i think it is included.
TRSguy
Post by TRSguy »
After double checking I found that the DRD file has a an outline as well as drill information.
