Gotek config issue
pink
Gotek config issue
Post by pink »
I have just updated the firmware on my Gotek USB device and now I cannot get it to respond to either the third button or to take any notice of the config file at all. I've tried using the autobot config and the index config but it still boots in normal mode. Any ideas at all? :?:
Re: Gotek config issue
Have you used the config files present into the firmware zip archive ?
Have you an LCD / OLED screen ? if so, try to enter the internal menu to clear the settings. (Or press the right button at power-up to clear the internal settings)
pink
Post by pink »
Thanks Jeff. Clearing the settings from the menu did the trick! :)
