CP/M emulation using ADC Super Quad and HXC emulator Rev 9
Re: CP/M emulation using ADC Super Quad and HXC emulator Rev 9
"a Rev 9 HXC emulator"
What is this ? Rev B, C or F ?
Can you share the images you are using ?
Which error did you get exactly ?
galasphere wrote: Fri Jun 08, 2018 8:30 pm Another example image is located at this link
http://www.retroarchive.org/maslin/disk ... index.html
The file name is adc-cpm.td0
It's too large to attach to this message
This image seems to have a bad sector. And i think that the RPM is wrong. Is the original disk drive rotation at 300 RPM or 360 RPM ?
galasphere wrote: Sat Jun 09, 2018 8:14 am I am not sure what the rotational speed of these images were created at.
I don't if it really matters as I am using them in their imaged state, that is not a real physical drive.
what is the old drive brand and model ?
i will post the current disk layout to show you the issue.
mysteron wrote: Fri Jun 15, 2018 9:54 pm Ok thanks.
It will be interesting to see what is causing the problem.
Here it is :
One bad sector + something wrong with the rpm or the sector gap.
