Gotek SFRC922D
prodigy
Gotek SFRC922D
Post by prodigy »
Hi, I bought a Gotek SFRC922D but when i short/solder J3 and the pin next to it to enter program mode - upon power up it's dead the LED doe's not light up. remove the link - it doe's.
Anyone know if they have changed the board pin layout?
Re: Gotek SFRC922D
You are on the HxC support forum. For the HxC firmware you need to use this tool :
https://hxc2001.com/download/floppy_dri ... Bridge.zip
This video is showing you the process :
https://www.youtube.com/watch?v=Q2qVgBJUI5U
prodigy
Re: Gotek SFRC922D
Post by prodigy »
I understand fully the process and I know how to install the correct firmware -
I had already downloaded and tested the software and it links up - and discovers the USB serial TTL device on com5 - The video was to show the pin configuration I'm using to put the board into programmer mode. (not the flashing process)
The Problem I am having is the goteck board will not power on when I jumper the two pins for programmer mode. So I can't flash the drive if it wont power on - to repeat my question - is this revision board SFRC922D different ? Any idea why it won't power on?
Re: Gotek SFRC922D
prodigy wrote: Sun Jun 03, 2018 4:44 am The Problem I am having is the goteck board will not power on when I jumper the two pins for programmer mode. So I can't flash the drive if it wont power on - to repeat my question - is this revision board SFRC922D different ? Any idea why it won't power on?
This is normal : In programming mode, the led and the display are off.
prodigy
Re: Gotek SFRC922D
Post by prodigy »
Perfect that's great - I'll try flashing it then - thank you Jeff
prodigy
Re: Gotek SFRC922D
Post by prodigy »
ok so I got it to flash - and the drive now says -ldr- Great
on the first attempt I did have a major problem - i got the blue screen of death - at 49/100 similar to the guy in this thread
https://hxc2001.com/floppy/forum/viewtopi ... =33&t=2025
I'm running Win7 64 bit
how I got round it was:
right clicked on SecSerialBridge.exe chose compatibility tab
selected run this program in compatibility mode and chose Windows Xp (service pack 3)
I ticked disable display scaling on DPI settings
Then ticked Privilege level - run as administrator
Hope this helps someone else.
prodigy
Re: Gotek SFRC922D
Post by prodigy »
If anyone could be kind enough to point me to info on how to pre-pair a usb stick to work with and Ensoniq EPS 16+
I'd be grateful as this would save me some hours researching :shock:
many thanks :D
Re: Gotek SFRC922D
prodigy wrote: Sun Jun 03, 2018 1:21 pm If anyone could be kind enough to point me to info on how to pre-pair a usb stick to work with and Ensoniq EPS 16+
many thanks :D
I think that you will find what you want into this archive :
:wink:
Re: Gotek SFRC922D
Note : For an Gotek without LCD/OLed screen : Rename the HFE files like this : DSKA0000.HFE, DSKA0001.HFE, DSKA0002.HFE... and use the indexed HXCSDFE.CFG file present into the firmware archive.
prodigy
Re: Gotek SFRC922D
Post by prodigy »
Done!! ran the UPD file added the HFE files all working - Ensoniq EPS 16+ OS loads up !!! thanks so much for the help
