HcX Update
Raycomp
HcX Update
Post by Raycomp »
I have a HcX bought in 2016. It came with update 1.8.2.40 from 2013.
I have used it with HFE files for my Dragon & CoCo.
Now I want to use it with my Acorn Electron ADFS machines.
Current updates from 3.1.0.4a have native support for ADF, ADM & ADL files so I would prefer to use one of those rather than convert to HFE with the recent software utility.
However my boot loader will not run them giving Error 4 (no update file) or 5 (header not recognised).
It is OK with the 1.8.2.40 update file.
I have tried update 3.0.0.0 which also fails.
Is there a solution for this problem?
Ray
Re: HcX Update
v3.X.X.X firmwares are for the Gotek HxC.
Raycomp
Re: HcX Update
Post by Raycomp »
OK. Thanks Jeff.
Ray
