I don't have the cables to make a firmware update, and I have no clue what update is on it. it has been flashed with hxc at least it says so when i turn it on. but nothing more happens.
I did format my usb stick on a pc with fat32 and a mac ms-dos format and copied those dsk000X and the cfg file and neither is working. I can not see any floppy id's and when I try to save or load it says that the drive needs to be formatted or it is memory protected etc. Ive been reading alot on the interwebs and found alot of info here
I just read her that the jumper was supposed to be on S1 but it was on the S0 on mine. I did the change but that did not do anything, maybe the green light on the drive started working but nothing more :/
So are the cfg Files only compatable with the right firmware updates? It also has the ib 9 scsi card installed , could that have something to do with it?
Is it possible to do the firmware update with the emulator installed on the S950?
Sorry for all the questions but I really need some help
