Tune HxC emul to 2 drive mode
algileer
Post by algileer »
I connect my HxC Emul to my pentium2
I set 8 jampers as follows:
1 ID0A OFF
2 ID1A ON
3 ID2A OFF
4 ID3A OFF
5 ID0B OFF
6 ID1B OFF
7 ID2B ON
8 ID3B OFF
I set BIOS drive a 1,44mb and drive b 1,44mb
I create HXCSDFE.CFG with 2 drives
I can not see drive select menu on HxC screen - I can select image to drive a only.
When i try read drive a - all are ok - HxC work with image
But when I try read drive b - emul red led blinks and the sound of absent disk read presents
What is wrong ? How to enable drive select menu ?
If I rewirte HXCSDFE.CFG - is it required to format sd card and write HXCSDFE.CFG first ??
Re: Tune HxC emul to 2 drive mode
When one image is selected, make a long press then select the drive A or B and select the other image.
algileer
Post by algileer »
Jeff wrote: Thu Mar 29, 2018 6:04 pm When one image is selected, make a long press then select the drive A or B and select the other image.
Thank You. I try it.
It is work.
Thanks again.
