Flash Bootloader:Device detected (0 units left)
tooty
Post by tooty »
Hi, there
This is the first time I start to flash the bootloader with your tool. Aftre try here and there, finally I got the "Device detected" message as mentioned in your instruction. But nothing happened when Program button pushed except TX and RX keep increasing(seems endless). And I never saw the progress like ".../100" described by others.
could you please help?
thanks.
Re: Flash Bootloader:Device detected (0 units left)
tooty wrote: Fri Mar 16, 2018 3:32 pm Hi, there
thanks.
Which account ?
tooty
Post by tooty »
account info:
ip:
Login: 49763530@qq.com
p/w: *
tooty wrote: Fri Mar 16, 2018 5:55 pm account info:
ip:
p/w: *
According to the server it seems that you have already flashed one device this morning ?:
[Fri Mar 16 11:43:23 2018] | --------- Device Signature --------- |
[Fri Mar 16 11:43:23 2018] | Block CRC : 9334
[Fri Mar 16 11:43:23 2018] | IDBlock - STM32 HxCFEBL
[Fri Mar 16 11:43:23 2018] | D:Fri Mar 16 11:42:52 2018
[Fri Mar 16 11:43:23 2018] | U:./ACCOUNT_3439373633353330407
[Fri Mar 16 11:43:23 2018] | S:-XXXXXXXXXXXXXXXXXXXXX
[Fri Mar 16 11:43:23 2018] | A:58.209.XXX.XXX:49375 -  -  -
[Fri Mar 16 11:43:23 2018] | ------------------------------------ |
tooty
Post by tooty »
really? I need to connect the display to confirm whether it's ok or not to flash the firmware tomorrow then let you know. but I'm pretty sure that I did not see the progress%.
thanks for your fast feedback and help anyway.
tooty wrote: Fri Mar 16, 2018 6:40 pm really? I need to connect the display to confirm whether it's ok or not to flash the firmware tomorrow then let you know. but I'm pretty sure that I did not see the progress%.
yes 100% sure, the drive is flashed.
tooty
Post by tooty »
yeees, it's flashed cos I saw Ldr sign after display put back on. now the hxc firmware was also installed. thanks a lot.
next, i'll try to get it into my arburg multronica to work.
tooty
Post by tooty »
dear jeff,
following the thread, i put everything in place, and plug it into the arburg multronica. the downloaded discs(multronica ones) were successfully read but i cannot write. could you please advise? thanks
tooty
Post by tooty »
forgot to mention the error msg, "synchrane error"
you got an email with something to test.
Let's continue the discussion by email.
