FIXED: Hxc Slim not detects DF1 after reboots
oscarbraindead
Post by oscarbraindead »
Hi all,
I'm having troubles with a hxc slim disk emulator in an Amiga 500, in order to get working df0 and df1 simultaneously.
The switchs 1 and 6 are ON and DF1 option is ON.
I start the disk manager, select two files in for the slot 1 (for A and B drives) and press F10. The system reboot and doesn't recognize the df1: drive. If I turn off the computer from the PSU and turn on it again, then df1 works flawlessly... once recognized, if I reboot the computer with the keyboard (Amiga keys + Ctrl) then the DF1: is lost again.
I'm using:
-amiga 500
-hxc slim emulator
-firmware v2.0.2.2
-disk manager version 1.14a
Is it a bug or the expected behavior?
Thanks in advance.
Edit: I've tried with a more recent manager version (v1.65a) with same results only detetcs the DF1: when turn off/on from PSU
EDIT2: updating the hxc firmware to 2.1.4.0 fixed the problem
Re: FIXED: Hxc Slim not detects DF1 after reboots
Fine ! :D
